Curl Velocity
Old   March 5, 2009, 11:24
Default Curl Velocity
Cardero
Hi, I am trying to use the USER_GETVAR to calculate the Curl of the fluid velocity. However I am facing problems to make it work. I even try to reproduce the USER CEL example 2 from the CFX help (Using gradient for an aditional variable source) and the following error message was produce: ERROR # 001100279 has occurred in subroutine ErrAction Message: Error in subroutine CONVERT_NAME_S2U
ERROR # 001100279 has occurred in subroutine ErrAction Message: solver Name = not recognized Has anyone faced similar problem
UDF error - parabolic velocity profile - 3D turbine Zaqie Fluent UDF and Scheme Programming 9 June 25, 2016 20:08
help with UDF for contact angle based on contact line velocity gandesk Fluent UDF and Scheme Programming 14 October 29, 2012 14:58
how to compute relative velocity from absolute? spk Main CFD Forum 3 July 9, 2010 09:42
what is Velocity Curl? CFD newbie Main CFD Forum 3 July 4, 2008 14:35
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 03:15
