Hi, I am trying to mesh a volume controle.
The flow pass between thow plate. The space between the to plate is 0.005in (0.13mm) and the area of the plate is 40in(1016mm) x 30in(762mm). The inlet flow is trought an orifice in the center of one of the two plate. I want to mesh this volume. With this géometrie, I need to mesh with a spacing max 0.005in(.13mm). When I try to mesh I see this error : Storage allocation failed Number of words requested 9956546 Array xyz I want to know if their is a way to mesh this king of géometrie. Tanks |
jus globally define the shell mesh.... and create da body pnt.... rest icem-cfd will take care....
In chx mesh, I change the default mesh scale factor.
And with that, I see this error: meshman.loadmesh(dm.files.get("surface.mesh"),fals e ![]() Did someone know what to do with this kind of error Tanks |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Create moving mesh without simulating (CFX) | spatialtime | ANSYS | 2 | July 22, 2010 10:30 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
hex mesh using cfx mesh. | mehul | CFX | 0 | October 31, 2005 07:01 |
Mesh from ICEM CFD to CFX ! Error ! Why ? Thanks ! | Vu Trinh Tuan | CFX | 11 | March 28, 2005 19:04 |
