Applying Heat Flux out of the surface in CFX
Old   February 25, 2009, 20:32
Default Applying Heat Flux out of the surface in CFX
Ijaz
How can we apply negative heat flux on a wall boundary in CFX?
Old   February 25, 2009, 21:04
Default Re: Applying Heat Flux out of the surface in CFX
Rikio
Ljaz,
You can set lower environment temperature to let heat flow out of the wall boundary... Wish help...
Rikio
Old   February 26, 2009, 01:06
Ijaz
Thanks Rikio. The temperature at the boundary in question is not uniform. Therefore, applying a convective heat transfer coefficient in conjunction with a lower environment temperature would not ensure the flux value that I want to apply. I have tried applying a negative heat flux, but it results in non-physical results. In a software like CFX, there must be a way to apply negative flux. I would appreciate any suggestions from some experienced user.
Old   February 26, 2009, 17:33
CFX can handle negative heat fluxes just as well as positive ones. Sounds like you either have an inaccurate simulation or the negative heat flux you applied is non-physical.
Heat Flux Wall Boundary Confusion. Joee FLUENT 1 August 21, 2010 13:20
Export Heat Flux CFX -> ANSYS Workbench Freeman CFX 2 April 11, 2010 09:24
constant surface heat flux Andrew Hayes Main CFD Forum 4 March 16, 2006 08:19
Heat flux on a irregular surface massimo Siemens 5 December 11, 2002 06:55
Heat Transfer Coeff. at Heat Flux Boundary Rushyen CFX 6 January 18, 2001 06:09
