User defined function causes error !!!!
Old   February 20, 2009, 14:18
Default User defined function causes error !!!!
CFDLife
I am using a user function (density changes with pressure) and using this density in the fluid properties. The simulation crashes every time I use this expression. If i don't use this expression and keep the density constant, it runs fine. I also tried checking the boxes for "Extend Min/Max", it still crashes.
Any suggestions???
Old   February 23, 2009, 10:07
Default Re: User defined function causes error !!!!
bharath
could u explain me the function u used.
Old   February 23, 2009, 12:29
CycLone
Be careful to remember that "Pressure" is the relative pressure, not absolute. If your function is related to the absolute pressure, use "Absolute Pressure" instead.
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 14:21
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 19:44
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
attach/detach (valve opening/closing) phsieh2005 OpenFOAM Running, Solving & CFD 2 March 21, 2009 06:18
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
