Mesh Motion pitch on a hull
Old   February 19, 2009, 11:10
Default Mesh Motion pitch on a hull
Seb
I am trying to simulate a transient wigley hull in waves free to heave and pitch using CFX. My main trouble is how to specify the pitch of the hull (or the rotation of the mesh on the hull) in terms of CEL expressions, where the mesh motion can be only defined in Cartesian coordinates and it has to be independent of the heave, to give the right pitch at any time. For the conservation of angular momentum there is a velocity variation of the angle that has to be found, but it seems that CFX doesn't allow defining mesh motion in cylindrical components and the decomposition of the angle could be affected by heave, so in the end the pitch is not the real one.
Any ideas of how to specify the pitch of the hull (mesh on the hull) in terms of CEL?
Many thanks in advance,
Old   February 23, 2009, 14:04
Default Re: Mesh Motion pitch on a hull
Edmund Singer
Seb:
Here is a sample of motion I have used for a specific application. The item moves around the Y axis located at XL,YL,ZL. You need to supply the logic for alpha, which is the angular rotation
NewX=-((z-ZL)-Total Mesh Displacement Z)*sin(alpha)+((x-XL)-Total Mesh Displacement X)*cos(w*t)+XL
NewY=-((y-YL)-Total Mesh Displacement Y) +YL
NewZ=-((z-ZL)-Total Mesh Displacement Z)*cos(alpha)+((X-XL)-Total Mesh Displacement X)*sin(alpha)+ZL
You then use Specifed Location for the mesh motions using NewX, NewY, NewZ
Negative Volume during Mesh Motion Analysis giov_ingr FLUENT 2 December 13, 2013 07:09
Dynamic moving mesh Pei-Ying Hsieh (Hsieh) OpenFOAM Running, Solving & CFD 64 June 7, 2012 11:04
a mesh motion question womo CFX 5 March 16, 2011 11:54
[ICEM] Structured mesh on ship hull nuovodna ANSYS Meshing & Geometry 4 March 4, 2010 11:19
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 20:43
