y+
Old   February 17, 2009, 15:09
Default y+
Gustavo
does someone know how to monitor the y+ near a wall? thanks in advance!
Old   February 18, 2009, 04:19
Default Re: y+
andy2o
Please see:
http://www.cfd-online.com/Forum/cfx_...cgi?read=26957
Regards, andy2o
Old   February 18, 2009, 11:47
Default Re: y+
cfdguy
Try areaAve(yplus)@wall as the Monitor Point. Don't forget to change to expression.
Good luck!
Old   February 18, 2009, 12:08
Default Re: y+
LKF
cfdguy: Have you tested your recommendation? I have tried this exact method and gotten an error in Pre. I have also tried creating a dummy monitor point and then changing the expression using "edit run in progress" once the solver is running and also gotten an error.
If in fact this is working for other people then I would like to figure what I may be doing wrong.
Old   February 18, 2009, 12:43
Default Re: y+
cfdguy
That's it, as I stated.
MONITOR POINT: yplusHood
Expression Value = areaAve(yplus)@box chimney
Option = Expression
END
Are you sure guys you're running a turbulent case?
Cheers!
Old   February 18, 2009, 12:49
Default Re: y+
LKF
Interesting ... and, yes, always running turbulence.
Next run I start, I'll try it again. Just speculating here, but I notice you listed 'yplus' whereas I've tried 'Yplus' and gotten errors, possibly that's the difference. Although 'Yplus' is the variable name listed in the documentation.
Old   February 18, 2009, 12:52
Default Re: y+
cfdguy
Ohh yes, the variables are case sensitive. If you look into the CFX installation dir under /etc subdir you'll find a VARIABLES file. Check inside and you'll find the correct names used by the solver.
Yplus is used by POST, I think.
Old   February 18, 2009, 16:13
Default Re: y+
Gustavo
thanks!! it worked!
