water line
Old   February 13, 2009, 06:28
Default water line
Ciro Cannavacciuolo
Hi, i have to calculate the water line of a simple 2d object. I'll use a static mesh and i'll move the free surface while the solid is blocked in its initial position. To calculate the velocity of freesurface i need to know, in every timestep, the velocity at the previous one. I have to use an external fortran routine. Could someone give me some information about this problem? Thanks!
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 09:48
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 05:26
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 16:16
