Inlet boundary conditions
Old   February 9, 2009, 14:25
Default Inlet boundary conditions
Mattia
Dear all,
good evening.
My name is Mattia and I am a PhD student at the Delft University of Technology (The Netherlands).
I am currently working in the turbomachinery field and I am focused on the analysis of a centrifugal compressor used in a micro gas turbine. The actual configuration has a vaneless diffuser and my idea is to enhance its performance by designing a vaned diffuser.
Anyway, let's talk about CFD.
I want to make a "rough estimate" of the flow field inside the vaneless diffuser and I am using CFX as CFD software.
I am simulating only one portion of the diffuser and only the diffuser itself. I have a 3D mesh.
Based on same papers I read, the best boundary conditions to use are pressure and temperature at the inlet (plus flow direction) and mass flow outlet. Thus, this is what I am trying to do and here the problems come out.
Of course I know the mass flow and I calculated the inlet conditions at the diffuser inlet (=impeller outlet) by means of velocity triangles (no experimental data available): it means I know the total pressure and temperature, plus absolute velocity (and its components) and the flow angles.
The biggest problem I have concerns the flow direction: how can I set it properly? Since I know the angles from the velocity triangles, I shouldn't have any trouble, but on the contrary I do have problems. Can you please help me with that?
Moreover, I read in the "help manual" that the total pressure to set as inlet b.c. is the RELATIVE TOTAL PRESSURE: does this mean that I have to subtract, from the calculated value, the reference pressure (=1 atm)?
I can provide you more details if needed.
Thank you very much!
Kind regards, Mattia.
Domain Imbalance HMR CFX 5 October 10, 2016 06:57
inlet boundary conditions mattia Main CFD Forum 0 February 11, 2009 07:06
Boundary conditions at Inlet for k and epsilon Tanmay FLUENT 1 January 26, 2009 11:42
periodic boundary conditions at the inlet Nacho Tauste FLUENT 0 January 14, 2009 13:34
how to set supersonic inlet boundary conditions xqy Phoenics 2 August 31, 2002 07:06
