Ploting pressure in line for transient simulation
Old   February 6, 2009, 00:06
Default Ploting pressure in line for transient simulation
lopese
Hy there,
I did some transient simulation and I want to plot the pressure distribution in a line location for each time in a cicle. Is it possible in CFX-Post? If not, how can I save the data in my chart as a xls or txt file?
Thanks in advance
Old   February 6, 2009, 10:59
Default Re: Ploting pressure in line for transient simulat
Rajee Assudani
Yes, it is possible. All you have to do is to load one of the transient results file and create the line (with pressure distribution). Then without closing this file, load other transient results one by one. You should see the pressure distribution on the line for each result file.
Old   February 6, 2009, 11:47
Smagmon
Mr. Assudani, I think that Mr. Lopese is trying to plot all of the transient pressure results in time. Something like a surface, with pressure x position x time. Isn't in? I have the same doubt about exporting data from CFX. Can somebody help us?
Old   February 6, 2009, 13:11
Rajee Assudani
Okay...This is how you can export the data..
1) Create the line location with pressure contours. 2) Click on File > Export. 3) Under locations, select the line that you created in step1. 4) Check box for Export geometry information. 5) Under select variables, select Pressure if that's what you want to plot. 6) Click Save.
This should save the data in excel spreadsheet.
Hope this helps!
Old   February 7, 2009, 12:25
lopese
Mr Assudani, thank you for your advice... but in this case, there is no way to save the values for each step all together. That is what i need. Does anybody now how to do that?
Thanks
Old   February 9, 2009, 10:42
Rajee Assudani
I think the only way to do that would be to write a PERL script which loops all the time steps and exports the data into separate files. You can then import all these files in excel.
Old   February 9, 2009, 12:54
lopese
Ok, I will try. I don`t know so much about PERL scripts. But thank you!
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
high pressure simulation mahi FLUENT 0 November 7, 2008 02:30
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
Does star cd takes reference pressure? monica Siemens 1 April 19, 2007 12:26
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
