Wall Heat Flux not a listed variable
Old   February 4, 2009, 16:43
Default Wall Heat Flux not a listed variable
mike
I've run a simulation on a rather complex system with heat and fluid flow. The entire purpose of the simulation was to view the temperature distribution and heat fluxes, but when I try to plot the heat flux, "Wall Heat Flux" isn't an option. I have "Heat Flux", but its values are unknown, so that isn't helpful.
Is there a reason why the "Wall Heat Flux" wouldn't have been computed?
Old   February 4, 2009, 17:24
Default Re: Wall Heat Flux not a listed variable
CycLone
If you solved for Thermal or Total Energy, Wall Heat Flux will be there... unless you specified the variables to be written to the res file and didn't include it. More likely it is what you are doing in Post that is wrong.
What kind of location are you trying to plot the wall heat flux on?
-CycLone
Old   February 4, 2009, 17:30
mike
Let's say I'm trying to observe the Wall Heat Flux by applying a contour onto the surface of a body which has a generation term. When I click the "..." button next to Variable, "Wall heat Flux" isn't there. If I check the "Variables" Tab, "Wall heat Flux" isn't there under "Solution" either.
I don't recall specifying that the "Wall Heat Flux" values not be written to the res file, I don't even know how to do that, how would I check to ensure it was written?
Old   February 4, 2009, 17:32
CycLone
If you didn't change anything under output control, the solver would write it by default, so this is probably not the problem.
What energy equation did you solve for?
-CycLone
Old   February 4, 2009, 17:35
mike
All domains used Thermal Energy.
Old   February 4, 2009, 17:57
CycLone
Well, I don't know what to say. It should be there. Did you pick the right RES file?
If the problem is reproducible (i.e. you can set up another case that demonstrates the same behavior), you may want to contact tech support. In my experience there is always user error at some point (don't fret, we all make mistakes), but its hard to diagnose without seeing the case.
Sorry if that isn't much help.
-CycLone
Old   February 5, 2009, 03:20
Marco Müller
you use Solid regions? I suppose, Wall Heat Flux can only be plotted on Solid boundaries...
Marco
Old   February 5, 2009, 12:19
mike
I did use a solid region.
To follow up on this problem, I have addressed it... to some degree.
"Wall Heat Flux" is still missing, and I still seem unable to plot the "Heat Flux" on a contour, but if I right-click on a named region in the Outline View, and change it from Constant to variable, the Heat Flux can be plotted, so I've been making use of this work-around.
Thanks for all the help!
Old   February 5, 2009, 14:32
cfdguy
Can you post your CCL here? It will be easier for a quick-checking... Definitely something is missing in your setup.
Need Help on Heat Flux Profile within Pipe Wall mep10jl FLUENT 3 June 6, 2011 18:08
groovyBC nonuniform Wall heat flux Shoonya Main CFD Forum 0 August 11, 2010 14:03
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 7, 2008 00:17
Basic question: UDF for wall heat flux Carl FLUENT 1 August 5, 2006 20:01
WALL HEAT FLUX V.S. HEAT FLUX tommy CFX 0 December 15, 2005 09:14
