February 4, 2009, 06:41 |
Exit code 247
Hi Does anyone know what an exit code of 247 means?
Is it memory related?? here's the verbose information:- MPI Application rank 0 killed before MPI_Finalize() with signal 9 An error has occurred in cfx5solve: The ANSYS CFX solver exited with return code 247. No results file has been created. thanks for help |
February 5, 2009, 08:26 |
Re: Exit code 247
MPI is hint to parallelization. Nevertheless to sure the failure is not caused by your setup take an tutorial example and start in the same as you do yet.
The FOAM Documentation Project - SHUT-DOWN | holger_marschall | OpenFOAM | 242 | March 7, 2013 12:30 |
Debugging Unsteady 2-D Panel Method Code: Wake Modeling | RajeshAero | Main CFD Forum | 5 | November 10, 2011 05:48 |
How to make code run in parallel? | cwang5 | OpenFOAM Programming & Development | 1 | May 30, 2011 04:47 |
Open Source Vs Commercial Software | MechE | OpenFOAM | 28 | May 16, 2011 11:02 |
Small 3-D code | Zdravko Stojanovic | Main CFD Forum | 2 | July 19, 2010 10:11 |
