January 30, 2009, 07:43 |
heat transfer
hi everyone.. i am a beginner user for ansys. i want to investigate the heat transfer of nitrogen gas inside chamber. so from where should i start? which physical preference should i use; CFD of mechanical? kindly appreciate ur help... thanks.
January 30, 2009, 22:30 |
Re: heat transfer
Sounds like you need to perform a CFX analysis. Check out some of the tutorials.
Two-sided Wall Heat Transfer BC - No Separate Solid Mesh and No Heat Transfer Coeff | swahono | OpenFOAM Running, Solving & CFD | 10 | October 15, 2018 06:43 |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
Convective / Conductive Heat Transfer in Hypersonic flows | enigma | Main CFD Forum | 2 | November 1, 2009 23:53 |
How can I increase Heat Transfer at Domain Interf? | B.Simon | CFX | 3 | October 28, 2008 19:53 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 16:55 |
