Parallel Deforming Mesh Simulation
Old   January 28, 2009, 13:39
Default Parallel Deforming Mesh Simulation
Tristan
I'm doing a piston-cylinder simulation with a deforming mesh. I'm using a cylindrical mesh (r,theta,z) with non-uniform spacing in r and z to resolve the cylinder wall and the piston face. I ran the calculation in parallel with 8 partitions and the mesh moves as expected, maintaining constant z grid lines on the cylinder wall as the piston moves toward TDC. However, when I ran it with 14 partitions, the nodes do not maintain the constant z grid lines and I eventually get negative volumes and CFX crashes. Do I have to do something special so that the partitioning doesn't lead to this type of behavior or can I only run deforming mesh simulations with a small number of partitions?
Thanks,
Tristan
Old   January 28, 2009, 18:59
Default Re: Parallel Deforming Mesh Simulation
The number of partitions should not affect the mesh motion. If it definitely is the number of partitions affecting the mesh motion I would report it to your support representative.
Have you tried this on V12 beta?
Problems in mesh motion solutor in parallel 4 interDyMFoam. DLC OpenFOAM 0 November 21, 2009 09:54
Mesh used for Combustion Simulation Stein CFX 5 May 14, 2009 19:24
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 15:09
How to access the mesh quality before simulation? Cheng CFX 2 November 18, 2006 00:56
Automatic Mesh Motion solver michele OpenFOAM Running, Solving & CFD 10 September 26, 2005 09:21
