Multiple domain interfaces on a single surface
Old   January 26, 2009, 00:17
Default Multiple domain interfaces on a single surface
mike
I'm having difficulty applying proper interfaces in a 3D simulation I'm trying to run. I have a two solids, overlapping partially, in an airflow, as seen below. Because of this, the top surface of solid 2 requires a solid-solid interface with Solid 1, and a solid-fluid interface with the surrounding air.
|.....Solid.1...|.....Fluid.....|
|............Solid.2..............|
When I apply both domain interfaces, I get errors saying:
"There are 2d regions in boundary 'Domain Interface Side 1' in domain 'solids' that have already been used." and "There are 2d regions in domain interface 'Domain Interface 1' that have already been used"
It seems to me that I should be able to partition or split the top face of Solid 2 along the line of contact, but I am unable to find any option to do so in Design Modeller, Meshing, CFX-Mesh, or CFX-Pre.
Any help would be greatly appreciated.
Old   January 26, 2009, 17:45
Default Re: Multiple domain interfaces on a single surface
CycLone
You can split the face in DM using a Body Operation with the "Imprint Face" option. Unfreeze Solid 2 and freeze all other bodies, then pick Solid 1 and Fluid for the operation, which will then imprint their faces on Solid 2.
-CycLone
Old   January 26, 2009, 18:03
mike
Thank you so much, this is exactly what I was looking for.
-mike
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 12:12
How to: Domain Interfaces Neusier CFX 8 March 22, 2011 07:34
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 13:43
CFX 5.5 Roued CFX 1 October 2, 2001 17:49
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
