how to create contour surface for some range
Old   January 23, 2009, 03:58
Default how to create contour surface for some range
sa
Dear CFX users
I want to plot the range of mach no from 1 to 1.6 in the fluid domain, my question is that
" how to create the surface for specified range of variable i.e mach no from 1 to 1.6"
In fluet it is easy. just we use the clip range command.
I m stuck in this problem
Any help will be highly appreciated.
Best Regards SA
Old   January 23, 2009, 05:00
Default Re: how to create contour surface for some range
Georg
Apply User specified Range(in Geomerty Tab of Contour object)
Old   January 23, 2009, 05:31
sa
Dear
Thanks for you quick reply. It is valuable comment but it is working only on the specified surfaces, for example, pressure inlet, wall etc. I would like to extract the whole range (e.g mach no from 1 to 1.6) in complete fluid domain not only on surface.
Hope i have made my self clear.
Regards SA
Old   January 23, 2009, 07:57
Jwala
Hi ,
If this is your problem you have addressed then the following points need to be seen: 1. Go to CFX post select contour from main bar,name the contour as contour 1. 2.In 'geometry'. Select the 'Domain' of interest 3.Select the 'location' you need to have contour. 4.Select the 'variable' as mach number if it is relative relative mach number you need. 5.Select the 'Range'1 to 1.6 6.Select the 'no. of contours' according to clarity. 7.Select 'Apply'. Any clarification required,do let me know.
Regards, Jwala.
Old   January 24, 2009, 10:23
sa
dear CFX users
Regards SA
Old   January 26, 2009, 03:40
Johannes
Then use volume > isovolume > variable: Machnumber > mode: between values.
Old   January 28, 2009, 15:36
sa
Dear Johannes; Thankd alot, you have solved my problem, this is what I needed. Best Regards
Contour Plot of a curved surface projected onto a flat plane Amp CFX 4 March 12, 2013 23:54
Wont let me create a surface from a sketch chay89 FLUENT 0 April 28, 2011 18:04
[snappyHexMesh] How to create a separate patch on a blockmesh surface bing.guo OpenFOAM Meshing & Mesh Conversion 0 April 24, 2011 12:35
solid edge problem....can you help? cindy Main CFD Forum 3 April 5, 2004 14:43
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
