January 23, 2009, 03:29 |
Point flow exception:overflow
I am facing problem in CFX-Simulation. Case is regarding Rotor-stator-Radial-splitter(Core and Bypass) case. Problem : point flow exception: overflow. I have checked with the BC'S and Initialisation. Could you please suggest? Regards, Jwala. |
January 26, 2009, 18:04 |
Re: Point flow exception:overflow
Your simulation is diverging. Read the section in the documentation about "obtaining convergence". This may also help: http://www.cfd-online.com/Wiki/Ansys...gence_criteria Glenn Horrocks |
January 27, 2009, 19:04 |
Are you running steady state simulation?
January 28, 2009, 08:08 |
Yes I am running steady state simulation. Regards, Jwala. |
January 28, 2009, 12:56 |
Under solver setting reduce your time step. It works for me when I do that!
January 29, 2009, 02:46 |
Thanks for the suggestion. I had done the same before but the convergence is not good. Regards, Jwala. |
January 29, 2009, 03:08 |
Thanks for the information. I will implement the suggested methods . Regards, Jwala. |
Problem with UDF compiling for kTkLW model | Wantami | FLUENT | 0 | July 18, 2011 06:11 |
ERROR #001100279,Floating point exception:Overflow | sohail ahmed | CFX | 4 | July 14, 2010 03:18 |
Mass flow and U-Mom flow in CFX | Zhihua Xie | CFX | 0 | September 3, 2007 10:49 |
Multiphase flow modeling | Paul | CFX | 2 | August 11, 2003 10:41 |
PhD in turbulence | Hans | Main CFD Forum | 14 | October 8, 2001 04:03 |
