multiphase flow, aeration
Old   January 14, 2009, 06:34
Default multiphase flow, aeration
Ellie
Im looking at designing an aerator in a siphon system where the downward flow and low preassure in the pipe draws in the air through the aerator and draws the bubbly flow down the pipe with the water flow. The simulation of the multiphase flow on CFD could be simular to that of the fuel mix in a venturi. Any help would be appreciated.
Old   January 14, 2009, 19:48
Default Re: multiphase flow, aeration
hi,
There are examples of an air-bubble reactor in the CFX tutorials. Have you looked at that example?
Old   January 15, 2009, 11:51
Ellie
Hey i have looked at the tutorial and worked through it however the example is looking at the upward bubbly flow and in the siphon system that i am looking at the bubbly flow is being forced into the downward flow.
Old   January 15, 2009, 18:33
So can't you just change the boundaries around to suit your application? What specifically is the problem?
Multiphase flow! Amer FLUENT 2 May 16, 2012 16:57
Multiphase flow information amir FLUENT 2 May 25, 2007 07:01
Realizable k-epsilon eqns for multiphase flow Rana FLUENT 0 December 8, 2006 14:46
Multiphase Flow mbga8ejf CFX 0 July 10, 2003 11:26
multiphase flow Shane Gillis FLUENT 10 August 28, 2000 20:12
