Simulation Time in restart runs
Old   January 14, 2009, 04:43
Default Simulation Time in restart runs
Elina
Hi pals! I'm completely new in CFX!
I wonder why the simulation time reported in cfx-post, starts from 0 sec, in restart runs ? how can I calculate total time of simulation when I continue a transient run using previous result?
Thanks for you advice
Old   January 14, 2009, 10:44
Default Re: Simulation Time in restart runs
cfdguy
Hi Elina,
You have to edit the command file and input the initial time as the latest value solved.
I was wondering wether there is an automatic way of doing it. I recall this issue has caused me some confusion (trouble) in the past.
Good luck!
Old   January 14, 2009, 19:16
latslosh
Just set the initial time option in the symulation type menu to 'automatic' or 'automatic with value' rather than 'value' and CFX will read the time value from your specified initial conditions file. If you have any time-dependent CEL, these will also use the correct time values.
Note that when you want to change meshes during the simulation, this does not work.
Hope that helps, latslosh.
Old   January 21, 2009, 04:57
Elina
dear Latslosh and CFdGUY Thank you very much for your advaices both of them worked out!
TimeVaryingMappedFixedValue irishdave OpenFOAM Running, Solving & CFD 32 June 16, 2021 07:55
Adding heat source to chtMultiRegionFoam maddalena OpenFOAM Programming & Development 61 February 17, 2018 09:33
Full pipe 3D using icoFoam cyberbrain OpenFOAM 4 March 16, 2011 10:20
Transient Simulation: Initial Time blackbody CFX 0 April 18, 2010 09:19
influence of time step in insationary simulation Sascha Behrens FLUENT 0 December 1, 2005 10:08
