pump validation
Old   January 12, 2009, 04:00
Default pump validation
Nitin Suryawanshi
Dear friends i did cfd analysis for centrifugal pump, and for max flow to design point(operating point) flow range cfd head is acceptable with experimental head, but for the flow below design point cfd head is decreasing & it is less for low flow rate, but theorotically head should be higher at low flow rate Can anyone please guide me resons behind this????
Thank You Nitin Suryawanshi
Old   January 12, 2009, 08:33
Default Re: pump validation
sa
how it is possible? as i know (correct me if i am wrong) for low head mass flow rate is higher, and for higher head mass flow rate is lower.
Centrifugal Pump CAD Model Required for validation bhatiadinesh CFX 1 June 25, 2013 05:16
Regenerative pump modelled in FLOEFD pro YYY FloEFD, FloWorks & FloTHERM 2 October 5, 2009 06:04
pump validation Nitin Suryawanshi FLUENT 8 April 1, 2009 15:27
Pump validation Nitin Suryawanshi Main CFD Forum 0 January 12, 2009 03:51
Discharge pump flow Ali Main CFD Forum 0 March 5, 2003 18:11
