Floating point exception: Invalid number
Old   January 9, 2009, 14:51
Default Floating point exception: Invalid number
Jinfeng
I am modeling a transient radiation heat transfer problem. Whenever I tried to run it, the solver crashed. The output files shows: ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Floating point exception: Invalid number
My model is in micrometer scale. I don't know if CFX can do modelings in such small scales like that or not. I can't figure out what caused that error. I would like to get some advice from experienced user and I would greatly appreciate any help. Thanks.
Jinfeng
Old   January 10, 2009, 05:49
Default Re: Floating point exception: Invalid number
dace
does it happen after the 1st or some iterations or you have 0 successful iterations? If you have at least some successful iterations please observe the maximal temperature/velocity. May be it tends to infinity?
Old   January 10, 2009, 12:42
Jinfeng
The solver crashed at the first iteration. Later, I tried to run a steady state simulation, same thing happened at the first outer loop iteration. Any idea of what's going on?
Thanks, dace!
Old   January 11, 2009, 14:34
dace
1. does it work without radiation heat transfer included? 2. which radiation model you use and what is absorption coeffiecient?
Old   January 11, 2009, 17:44
The length scale of your simulation is fine. That is not the cause of the problem. You simulation has diverged. Read the documentation about "obtaining convergence" and also this page this may help:
http://www.cfd-online.com/Wiki/Ansys...gence_criteria
floating point exception? syd STAR-CCM+ 3 April 20, 2010 19:55
'floating point error :Invalid number' for energy eq. amirbahador FLUENT 0 March 23, 2010 05:04
Floating point exception error with small DeltaT rassilon OpenFOAM Running, Solving & CFD 19 September 2, 2009 08:39
"Error: Floating point error: invalid number" MI Kim FLUENT 2 January 4, 2007 11:00
Floating point error - invalid number draussen FLUENT 0 June 22, 2006 16:10
