CFX Mesh crashing
Old   December 24, 2008, 12:07
Default CFX Mesh crashing
Blade
Hello.
I seem to be getting a problem with CFX Mesh that I cannot solve. Basically, the .gtm file is stored but it appears that the meshing programme crashes after this stage. It therefore hangs at the 'Commit Mesh' stage. Is this a common problem or is the mesh that I am creating causing it?
Any help will be appreciated.
Old   December 29, 2008, 05:53
Default Re: CFX Mesh crashing
Timon
This is some common bug in CFX-mesh, it happens to me quite often as well (mostly for larger meshes). The mesh stored in the .gtm should be fine though. Just kill CFX-mesh and continue working with the created file.
Old   December 29, 2008, 14:03
John S.
I get this a lot when I construct large models. You can turn this option off under Tools - Options - CFX Mesh.
Old   December 30, 2008, 11:30
Blade
Thanks for the info. so far. John S, what option should I change within the CFX-mesh options window?
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Create moving mesh without simulating (CFX) spatialtime ANSYS 2 July 22, 2010 11:30
Mesh from ICEM CFD to CFX ! Error ! Why ? Thanks ! Vu Trinh Tuan CFX 11 March 28, 2005 20:04
importing mesh from ICEM CFD into CFX 5 Jay CFX 2 November 12, 2002 14:46
convert FLUENT mesh file to CFX mesh file?? frederic felten FLUENT 5 December 6, 1999 10:32
