Lift & Drag forces from Transient Analysis
Old   December 4, 2008, 18:12
Default Lift & Drag forces from Transient Analysis
Richard
If I run a transient analysis, how do I get the force to use for calculating the drag and lift coefficient, since the force change with time ?
Old   December 4, 2008, 18:40
Default Re: Lift & Drag forces from Transient Analysis
Either post-process it in CFX-Post for each transient result file you saved or set up a monitor point with a function like force_x()@surfacename and when you run the simulation you can access the forces in Solver Manager.
[OpenFOAM] Calculating Lift and Drag in Paraview (paraFoam) scott ParaView 26 August 22, 2019 07:26
Measure lift and drag forces in 3D henna07 ANSYS 1 October 17, 2011 17:18
coefficient of lift and drag forces nkiru FLUENT 9 August 14, 2008 02:00
Drag and Lift forces extremely low João Lourenço FLUENT 4 January 28, 2008 14:25
High lift analysis using overset kei-tee Main CFD Forum 0 April 10, 2003 10:53
