Drag force difference between Solver and Post
Old   November 20, 2008, 18:50
Default Drag force difference between Solver and Post
Dre
I am interested in finding the drag force of a blunt body.
When the solution is solving, I create a new monitor for the force on the surface in the Z direction. When I go to CFX Post and use the function calculator to get the force in the Z direction for the surface, I get a different answer than the one in the solver.
So which one is right?
Old   November 21, 2008, 10:59
Default Re: Drag force difference between Solver and Post
Dre
Could it be that CFX Post adds the viscous shear force? Because all of the drag forces in Post are higher then the ones in the Solver.
Old   November 21, 2008, 13:02
Default Solved, I think
Dre
I pretty sure that the difference is in the shear force. I was previously working with very small velocities, so the impact of the shear force was big. But now I'm working with regular velocities, and the impact is negligible.
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 16:45
drag monitore wrong but in post it's ok! zeitistgeld CFX 3 August 12, 2009 08:09
Drag force computation Martin Main CFD Forum 9 July 11, 2008 10:10
Actual drag force from dimensionless equations slaxmi CFX 10 September 14, 2007 20:20
How to determine the Drag Coefficient using POST? Hans CFX 0 January 18, 2006 20:53
