Is animation possible for Steady state model???
Old   November 12, 2008, 01:51
Default Is animation possible for Steady state model???
NI3
its urgent***
would anybody tell me.. is animation possible for steady state problem?
consider my problem: i am using a free surface model where by changing water height , i mam getting different types of hydraulic jumps. **I want to know weather this jump is stationary or moving ?????**
is there any alternative solution for this problem...
please specify.
thanks in advance..
Old   November 12, 2008, 03:45
Default Re: Is animation possible for Steady state model??
pmp77
I don't know if it helps you or not,
I modelled a steady state gas flow through a geometry and used particle tracking to animate the movement of the gas.
This is how i did:
More complex way:
In cfx pre: Creata a new material lets call it tracking_sand. Select Pure Substance and Particle Solid on Basic setting tabs. I gave 1 kg/kmol molar mass, and 0.001g/cm^3 density. You might need to give 0 J/kgK heat capacity (Material Properties tab)
In domain:default domain, General options turn on particle tracking and select your tracking_sand. In Fluid details select solid particles, Particle diameter distribution, i defined specified diameter 1 micron and non buoyant for the tracking_sand. on fluid pairs tab select one way coupling for water/tracking_sand if you do not want the tracking particles to influence the flow. It makes solver finish sooner as well. I used Shiller Naumann Drag Force.
At inlet settings: Fluid Values Tab: select Particle Behaviour for the tracking_sand in Mass and momentum select zero slip. it makes the particles move with the fluid without any slip. In number of positions I used direct specification and 1000/s at number rate; and 1 g/s for particle mass flow.
At wall: you can see the tracking_sand appear in fluid values. I used default values, and clicked ok.
Solve it
In cfx-post you will find Res PT for tracking_sand in its geometry tab you can change the limts option and use different values for your animation.
Or a much more simple way: create streamline in cfx post. Right click on it on the screen and select animate!
I hope you can adopt these for your problem
pmp77
Atomization and Breakup model xck1986 OpenFOAM 4 May 31, 2014 05:43
Wrong calculation of nut in the kOmegaSST turbulence model FelixL OpenFOAM Bugs 27 March 27, 2012 10:02
Turbulence Model and limitation to Reynolds number qascapri FLUENT 0 January 24, 2011 11:48
multi fluid mixture model issue rystokes CFX 3 August 9, 2009 20:13
simulation results for k-w model and SST model Li CFX 7 June 29, 2007 05:19
