Contour plot with negative velocity
Old   November 11, 2008, 07:47
Default Contour plot with negative velocity
J
Just to let you know the solution of the riddle...I was using log scale...and of course the log scale can't use negative numbers... So, with linear scale and local values of the variables it works perfectly. Sorry about this stupid problem.
Old   November 12, 2008, 16:42
Default Re: Contour plot with negative velocity
CycLone
Hi J,
Thanks for the update. Don't feel stupid; we've all been there. It never occurred to me to ask whether it was linear or log (most users don't realize they can plot on a log scale).
So I have to ask, were you also plotting on a log scale in Tecplot?
-CycLone
Old   November 13, 2008, 04:48
J
Hi man! Nope, on tecplot I used a normal linear scale. But I want to check also the log scale...and see what Tecplot says to me...
Old   November 13, 2008, 12:25
CycLone
I'd be interested in what Tecplot does. The problem with the log plot is you can never get to zero in order to cross over from negative to positive. One solution would be to have a lower limit on the log scale, after which it switches from positive to negative.
You can emulate this in Post by creating a contour with two levels, one below zero and one above, creating user surfaces on each level, then creating a logarithmic contour on each side with inverted color ranges.
-CycLone
[OpenFOAM] basic question contour plot in paraview Kate ParaView 7 July 23, 2020 15:05
How to Contour plot for omega_z ?? snehal OpenFOAM 3 March 11, 2017 06:41
[OpenFOAM] Contour Plot with Paraview jet ParaView 0 August 26, 2010 11:30
contour plot help jesse@uconn FLUENT 0 February 15, 2010 20:05
Velocity plot J CFX 5 October 27, 2008 13:13
