Face centered or vertex centered
Old   November 4, 2008, 11:42
Default Face centered or vertex centered
tommy
Does Cfx uses a cell-centered or vertex-centered finite volume approach ?
Thank you very much for the attention
Tommaso
Old   November 4, 2008, 12:47
Default Re: Face centered or vertex centered
CycLone
CFX uses vertex-centered finite volume.
Old   November 13, 2008, 00:52
HekLeR
CFX additionally uses finite element shape functions to approximate the profile within the elements. As opposed to a cell centered discretization being applied at each face connecting two mesh vertices.
Or, maybe this is more clear:
You put solution points on the vertex and use either: a cell centered (not sure if a commercial code does this) or a FEM discretization (like CFX). Or, your solution points are at cell centroids and you use a cell centered discretization (like FLUENT for example).
Any of the methods should pretty much give the same answer under a mesh refinement and will also have similar mesh convergence...
[blockMesh] Internal walls of zero thickness anger OpenFOAM Meshing & Mesh Conversion 23 February 6, 2020 19:25
[CAD formats] my stl surface is seen as just a line rcastilla OpenFOAM Meshing & Mesh Conversion 2 January 6, 2010 02:30
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
NACA0012 geometry/design software needed Franny Main CFD Forum 13 July 7, 2007 16:57
