Sinusoidal velocity settings ?
Old   November 3, 2008, 05:54
Default Sinusoidal velocity settings ?
Adenlan
Hi everyone,
I'm trying to setup a sinusoidal current in cfx but it seems I don't use the proper way. I set the simulation on transient mode in inlet boundary I use a cartesian velocity with expression : U=0 V=0 W=W [m s^-1]*sin(pi[rad s^-1]*t) and initial conditions set to 0 . The problem is that it does not converge instead each iteration I have this message :
****** Notice ****** | A wall has been placed at portion(s) of an OUTLET boundary condition (at 76.5% of the faces, 77.1% of the area)to prevent fluid from flowing into the domain. The boundary condition name is: outlet.The fluid name is: Water. If this situation persists, consider switching to an Opening type boundary condition instead.
Please someone help me !
Old   November 3, 2008, 06:12
Default Re: Sinusoidal velocity settings ?
Adenlan
Don't mind, my error is too obvious
Old   November 4, 2008, 07:47
underGroundMan
Set your outlet to 1 atm and reference pressure to zero.
Old   November 6, 2008, 13:13
Amod
By definition, Inlet Boundary condition should have flow always into the domain and Outlet Boundary condition should have flow always out of the domain.
By specifying inlet velocity profile as a function of time, you are changing the magnitude and direction of flow at the inlet boundary. This is not acceptable mathematically!
You may have to use moving boundary problem such as movement of Piston in an internal combustion engine.
Hope it clears! Amod
Old   November 7, 2008, 04:49
Rui
Why is it not acceptable mathematically?
What happens when one defines a negative (outwards) velocity on an Inlet Boundary in CFX?
P.S. There's nothing wrong in changing the magnitude of the flow at an Inlet Boundary, is there?
Old   November 12, 2008, 07:02
underGroundMan
I agree Rui. I have used time varying boundary condition many times and it works fine.
UDF error - parabolic velocity profile - 3D turbine Zaqie Fluent UDF and Scheme Programming 9 June 25, 2016 20:08
how to compute relative velocity from absolute? spk Main CFD Forum 3 July 9, 2010 09:42
How to calculate Velocity? Kali Sanjay Phoenics 1 May 1, 2006 14:57
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 03:15
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
