October 29, 2008, 06:24 |
LES and combustion model
Hi!
I'm working with CFX 11.0. I would like to study the combustion into a combustion chember using LES turbulence model. But I've a problem: when I set LES Smagorinsky model, CFX allows me to set only the Finite Rate Chemistry combustion model. But when you set LES Smagorinsky model and Finite Rate Chemistry model and you re-open the Fluid model options, CFX changes automatically the LES model into the k-epsilon model. In fact CFX mantains the LES model only if you set "none" option for the combustion model. What I have to do to use both LES and FRC models? If you know what the matter is, please help me.. Thank you very much!!!!! Margherita |
Weller combustion model - engineFoam solver. | ghindi | OpenFOAM Running, Solving & CFD | 1 | May 6, 2016 06:56 |
doubt about DNS and LES of combustion | chinthakindi | Main CFD Forum | 5 | August 17, 2013 12:56 |
[Gmsh] trouble with les model in XiFoam after convertion gmshTofoam? | lfgmarc | OpenFOAM Meshing & Mesh Conversion | 0 | May 25, 2011 00:35 |
LES of Non-Premixed Combustion in CFX?? | Manu | CFX | 5 | February 25, 2008 17:34 |
turbulence model in internal combustion engine | George | Main CFD Forum | 0 | December 4, 2006 19:01 |
