October 28, 2008, 09:16 |
Reaction help!!
Dear all,
I want to simulate propane/air premixed flame propagating in a curved duct. I creat a 4-step reaction for it. And it is ignited by a source point. But I find the reaction doesnt happen, i.e., the flame doesnt spread. Who can help me!!!! Many thanks! |
October 28, 2008, 15:13 |
Re: Reaction help!!
Could be a lot of things going on here. Some things to check: make sure your extinction temperature is set low enough for combustion to occur; try increasing the temperature of/amount of gas being injected by your ignitor point.
Barring that I would double check your reaction setup. |
October 29, 2008, 00:53 |
Re: Reaction help!!
This may sound really silly, but I had a problem when I first implemented a reaction (it wasn't flame but liquid), however no matter what I did with the reaction rates it just did not react I couldn't work it out. This was until a friend of mine pointed out that I still had the reaction or combustion option set to none in the fluid models tab in the domain. If I remember correctly I set it to finite rate chemistry and it worked after that.
Hope this helps |
October 30, 2008, 02:06 |
Re: Reaction help!!
Thanks all.
Maybe the post is a little longer. The reactions I used in the simulation are as follows: REACTION:Propane Air 4step Additional Materials List = C3H8,O2,CO,CO2,H2O,H2,N2 Option = Multi Step Reaction Description = Propane Air Four Step Reactions List = step 2,step 3,step 4,step1 END REACTION:step 2 Option = Single Step FORWARD REACTION RATE: Option = Arrhenius Pre Exponential Factor = 1.67E7[mol^-1 cm^3 s^-1] Temperature Exponent = 0 REACTION ACTIVATION: Activation Energy = 125615.47 [J mol^-1] Option = Activation Energy END END PRODUCTS: Materials List = CO,H2 Option = Child Materials CHILD MATERIAL:CO Option = Stoichiometric Stoichiometric Coefficient = 3 END CHILD MATERIAL:H2 Option = Stoichiometric Stoichiometric Coefficient = 7 END END REACTANTS: Materials List = C3H8,H2O Option = Child Materials CHILD MATERIAL:C3H8 Option = Stoichiometric Reaction Order = 1.0 Stoichiometric Coefficient = 1.0 END CHILD MATERIAL:H2O Option = Stoichiometric Reaction Order = 1.0 Stoichiometric Coefficient = 3 END END END REACTION:step 3 Option = Single Step FORWARD REACTION RATE: Option = Arrhenius Pre Exponential Factor = 7.94E13[m^2.250 s^-1 K mol^-0.750] Temperature Exponent = -1 REACTION ACTIVATION: Activation Energy = 167478.97 [J mol^-1] Option = Activation Energy END END PRODUCTS: Materials List = H2O Option = Child Materials CHILD MATERIAL:H2O Option = Stoichiometric Stoichiometric Coefficient = 1.0 END END REACTANTS: Materials List = H2,O2 Option = Child Materials CHILD MATERIAL:H2 Option = Stoichiometric Reaction Order = 0.25 Stoichiometric Coefficient = 1.0 END CHILD MATERIAL:O2 Option = Stoichiometric Reaction Order = 1.5 Stoichiometric Coefficient = 0.5 END END END REACTION:step 4 Option = Single Step FORWARD REACTION RATE: Option = Arrhenius Pre Exponential Factor = 1.538E8[mol^-1 cm^3 s^-1] Temperature Exponent = 0 REACTION ACTIVATION: Activation Energy = 83743.64 [J mol^-1] Option = Activation Energy END END PRODUCTS: Materials List = CO2,H2 Option = Child Materials CHILD MATERIAL:CO2 Option = Stoichiometric Stoichiometric Coefficient = 1.0 END CHILD MATERIAL:H2 Option = Stoichiometric Stoichiometric Coefficient = 1.0 END END REACTANTS: Materials List = CO,H2O Option = Child Materials CHILD MATERIAL:CO Option = Stoichiometric Reaction Order = 1.0 Stoichiometric Coefficient = 1.0 END CHILD MATERIAL:H2O Option = Stoichiometric Reaction Order = 1.0 Stoichiometric Coefficient = 1.0 END END END REACTION:step1 Option = Single Step FORWARD REACTION RATE: Option = Arrhenius Pre Exponential Factor = 3.49E10[mol^-0.75 cm^2.25 s^-1] Temperature Exponent = 0 REACTION ACTIVATION: Activation Energy = 125615.47 [J mol^-1] Option = Activation Energy END END PRODUCTS: Materials List = CO,H2 Option = Child Materials CHILD MATERIAL:CO Option = Stoichiometric Stoichiometric Coefficient = 3 END CHILD MATERIAL:H2 Option = Stoichiometric Stoichiometric Coefficient = 4 END END REACTANTS: Materials List = C3H8,O2 Option = Child Materials CHILD MATERIAL:C3H8 Option = Stoichiometric Reaction Order = 0.5 Stoichiometric Coefficient = 1.0 END CHILD MATERIAL:O2 Option = Stoichiometric Reaction Order = 1.25 Stoichiometric Coefficient = 1.5 END The unit for the Pre Exponential Factor in literature is kg.m-1.s-1. I dont know how to transform it to suit for the cfx. And when the solver starts, I get the information: Enthalpy per [mol] of reaction at reference conditions (Pressure= 1.01325E+05, Temperature= 2.98150E+02) step1 = 2.2776E+05 step 4 = 4.1159E+04 step 3 = 2.4185E+05 step 2 = -4.9779E+05(I dont why this step's enthalpy is negative.) The ignition I define is just like this: spark = (0.005[kg m^2s^-2]/sparktime)*step(t/1.0[s])*step((sparktime-t)/1.0[s]) sparktime = 1.0*(10^-3)[s] Are there any other better ways to get the premixed gas ignited? |
October 30, 2008, 10:11 |
Re: Reaction help!!
The way I define my ignitor is is via a sourcepoint with total mass flow on the order of 1% of the total domain flow. I inject only combustion products and set the temperature very high, usually to what I expect the temperature to be if combustion was taking place. I give it some small velocity component in the axial direction, usually only .01 m/s. Depending on your turbulence model you'll have to define some other values but I usually use SST with k = 210.655 [m^2 s^-2] and omega = 277.3 [s^-1] (based off a jet-in-crossflow study).
I also set up a serires of monitor points for temperature downstream of the ignitor in order to judge whether or not I'm combusting. I'll place one just aft of the ignitor, and then a series of points at different axial locations downstream, usually three points or so at each axial location that are located at different y coordinates so I can get an idea of the temperature profile. Once I've determined that combustion is taking place I shut the ignitor off by setting its massflow rate to zero. It's important to shut the ignitor off and let the model run out before considering the results converged. This method has worked consistently well for me, at least with the 23-step finite rate model I use. Something I just noticed on your spark equation is that it's based off time, so unless you use a sufficiently small timestep you will have problems igniting. That goes for the ignition method described above as well. I usually use a physical timestep of .0001 [s] for my combustion CFD. If your's is significantly higher I might try rerunning it with the smaller timestep before trying this method. John |
Segmentation fault in running alternateSteadyReactingFoam,why? | NewKid | OpenFOAM | 18 | January 20, 2011 16:55 |
reaction in UDF(DEFINE_VR_RATE) | louiza | FLUENT | 3 | October 13, 2010 23:59 |
CFX5.7 - chemical reaction problem... | H.L. | CFX | 4 | March 25, 2009 10:33 |
chemical reaction - decompostition | La S. Hyuck | CFX | 1 | May 23, 2001 00:07 |
chemical reaction - howto | Dan Sorensen | Siemens | 1 | February 21, 2000 09:20 |
