CFX Solver to run 10 files sequentially
Old   October 27, 2008, 23:02
Default CFX Solver to run 10 files sequentially
Raj
Friends,
I would like to know how to set up CFX Solver to run/solve 5 to 10 .def files in CFX sequentially with windows configuration
Old   October 28, 2008, 00:35
Default Re: CFX Solver to run 10 files sequentially
Use the command line method of starting CFX (cfxsolve -definition 123.def) and stick the simulation sequence in a Windows batch file or Linux/Unix shell script.
Old   October 28, 2008, 00:56
Raj
Hi Glenn,
Thanks a lot for your reply. I have Project 1. def, Project 2.def,...till Project 10.def. I have never tried command line before. If you can provide me some examples to do that, that would be great!
Many thanks in advance!
Old   October 28, 2008, 02:41
onn
Hi Raj, Try this C:\progra~1\ansysi~1\v110\cfx\bin\cfx5solve -def D:\Project1.def C:\progra~1\ansysi~1\v110\cfx\bin\cfx5solve -def D:\Project2.def etc... where C:\progra~1... is software installed location and D:\Project1.def is .def file location
rgds Onn
Old   October 28, 2008, 03:46
Raj
Thanks a lot Onn and Gelenn for your kind helps.
Old   October 28, 2008, 12:51
CycLone
If you launch the command line from the CFX Launcher, the solver will already be in the path.
How do your runs differ? Are there changes in geometry, boundary conditions, etc?
-CycLone
Old   October 28, 2008, 21:15
Raj
Hi CycLone,
I need to solve 5 10 10 definition files sequentially in the night time. So, pls let me know if there are any other methods.
Thanks a lot!
Old   October 29, 2008, 09:35
CycLone
What Glenn has proposed will work; just create a .bat file or shell script that launches one after the other (one solve command per line will do it).
If the cases differ by parametric changes in geometry or operating conditions, you can also use DesignXplorer to set up a parametric analysis and specify the parameters you are interested in running. You don't need a license for DesignXplorer to do this, but you will need to run the entire thing within Workbench.
So, what is it you are varying?
-CycLone
Old   October 29, 2008, 23:20
Raj
Hi CycLone,
Thanks for your helps. Yes, I do parametric changes. I will try as you suggested.
Thanks again!
viewing cfx post while working on cfx solver manager HMR CFX 5 March 9, 2011 23:33
CFX solver error kh_thakor CFX 3 January 11, 2011 17:39
why the solver reject it? Anyone with experience? bearcat CFX 6 April 28, 2008 15:08
Variables Definition in CFX Solver 5.6 R P CFX 2 October 26, 2004 03:13
CFX 5.5 Roued CFX 1 October 2, 2001 17:49
