Is it possible to do CFX simulation of Rayleigh Taylor fluid instability. I have to match my experimental result from simulation for various inputs. I need some guidance to create simulation using CFX as its given in the animation below http://fluid.stanford.edu/~fringer/m...onvect/rt.html Thanks in advance Dinesh Kumar |
Yes, it is possible. Some hints - use second order time and space differencing; do a mesh, timestep and convergence sensitivity study to check these parameters are OK; and finally get access to a big computer to run it on as it is going to take plenty of computing power. Glenn Horrocks |
Dear Glenn,
If possible can you please write the hints in a bit details or mail me at dkverma.iitk@gmail.com . As I never did simulation I just went through some easy ANSYS tutorials. Basically my work is experimental and I am interested to do its simulation using ANSYS. Thanks Dinesh |
Work through relevant tutorials, read the documentation, have a look on the CFX-Community site for relevant technical tips, have a look in the literature for what other people do. I am not going to summarise 15 years of CFD experience in a "how to CFD" guide, I don't have the time. Glenn Horrocks |
hello dinesh, what are you studying there in IITK.?
Error message: Insufficient Catalogue Size | Paresh Jain | CFX | 33 | August 16, 2024 05:09 |
Cht tutorial in 15 | braennstroem | OpenFOAM Running, Solving & CFD | 197 | June 10, 2015 03:02 |
Impact simulation of container filled with fluid | worasit | CFX | 0 | April 21, 2004 13:53 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
Simulation of fluid flow through nozzles | Spiegel | Main CFD Forum | 3 | May 10, 2001 03:30 |
