time dependent pressure BC on outlet
Old   October 22, 2008, 09:05
Default time dependent pressure BC on outlet
sometimes1900
Hi CFX user, i would like to set up a time dependent pressure boundary condition on the outlet, e.g. from 0-5s, pressure=0bar; from 5-10s, pressure=1bar; from 10-15s, pressure=0bar and so on. How can this Expression (CEL) be wroten? thank you for your reply in advance.
Old   October 22, 2008, 11:13
Default Re: time dependent pressure BC on outlet
Rogerio Fernandes Brito
create (or define) an user function to input your time [s] and pression [N m^-2]. Make an 1D interpolation.
Arguments Units: [s]
Results Units: [N m^-2]
Interpolation Data -> Option -> One Dimensional
Create a name.txt file and build your data (time and pression using dot as your decimal separator).
After that, choose your pression as name(t) as your boundary condition, where t is the time in [s].
Old   October 22, 2008, 12:16
sometimes1900
Hi Rogerio, thanx for your reply. As you describled, i have defined an user function (name: function 1) in PRE. But in the outlet window i can not find the user function. How can i put the user function to outlet BC? Best regards
Old   October 22, 2008, 14:29
put "function 1(t)" in the box for the outlet. Just it. Donīt use space, in the name of the function. Use: "function1(t)"
Old   October 24, 2008, 12:14
Adam
An easier way would be just to create a CEL expression and input that into the outlet
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 17, 2019 00:12
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
Modeling in micron scale using icoFoam m9819348 OpenFOAM Running, Solving & CFD 7 October 27, 2007 01:36
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
