Problem in Initializing Blocking for 2d geometry
Old   October 21, 2008, 09:37
Default Problem in Initializing Blocking for 2d geometry
nitin Dewangan
hello, i am getting problem in initializing block for 2d geometry which is very simple geometry. geometry consist of a one step tank shape either it is going upward or downward.
dimensions are as follows: total length of tank 1 m. after .5 m one step is there in tank, so that i can study jump, for the remaining length.
please anybody tell, why i am facing difficulty, please try and solve it as soon as possible.
thanks..
Old   October 22, 2008, 02:43
Default Re: Problem in Initializing Blocking for 2d geomet
rohit
does the block does not initialize or whats the problem? could you explain a bit more
Old   October 22, 2008, 03:27
Nitin Dewangan
plese don't post any answer, i have solved this problem.
thanks to all.
Old   October 22, 2008, 10:58
Rogerio Fernandes Brito
Dear Mr. Nitin, i sent the mesh for you and the block for you. BUT, i did choose any lenght to your geometry. To make the geometry, use SolidWorks 2008 software. Itīs a good tool to build the geometry, instead of using the "CAD" tool within the ICEM CFD.
Old   October 22, 2008, 11:48
nitin Dewangan
thanks Mr. Rogerio..
i can use solid works but again same thing is that, i will have to learn that software. i am now used to of ICEM, and can make any type of geometry, so its better to go with ICEM. i have to finish my project work in 1 year only.
thanks
Old   October 22, 2008, 14:31
the cad tool of the icem cfd itīs very boreing to make the geometry. U can make the geometry in solidworks, save as "name.step" file and import in ICEM CFD.
Old   October 24, 2008, 02:03
Nitin Dewangan
isn't this a loss of time..
making geometry and exporting to ICEM, when ansys has facility to make geometry through ICEM , so why shouldn't we use this.
thanks rogerio...
[ICEM] O-grid around wing geometry Anorky ANSYS Meshing & Geometry 15 November 27, 2017 14:43
Gambit geometry problem cestrin FLUENT 3 July 4, 2012 03:33
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 20:42
Problem in k-eps turbulence code in complex geometry sontukaku Main CFD Forum 2 December 28, 2010 01:44
Geometry setup for phase change problem Fred G. Kang Main CFD Forum 1 October 14, 1998 12:41
