October 20, 2008, 02:24 |
Please help me out: Linear solver overlow
I am running the simulations of a turbulent jet flow. The simulition is successfully finished when i use 1e-3 sec as the time step. However, when i change to use 1e-4 sec (with the same setup of the others), there is always a overflow problem. I thought it was due to the mesh quality. So i checked it in Ansys ICEM. It said the quality was good. Does anyone confront this kind of problem? please give me some clue. Cheers!
October 20, 2008, 12:19 |
Re: Please help me out: Linear solver overlow
This can sometimes happen if you have too fine a mesh as well. Check your domain advection time. A typical time step is usually 1 advection time whereas 1/3 of the advection time would be considered small but can aid convergence.
October 20, 2008, 22:29 |
Using either a smaller timestep or finer mesh often causes the simulation to loose stability. There are a number of reasons but the most common one is that the mesh is now starting to resolve turbulent eddies. This leads to a minimum size allowable for timesteps. That is why it is recommended to increase the timestep agressively in steady state simulations after the initial transient is under control. Glenn Horrocks |
October 21, 2008, 01:18 |
Thanks, Glenn. When you said 'increase the timestep agressively in steady state simulations after the initial transient is under control', do you mean that i should do a steady-state simulation first to get some results to set as the initial conditions for the later transient simulation?
October 21, 2008, 01:44 |
Thanks for the response, John. I have a rookie question: how to check the advection time of my domain? cheers.
October 21, 2008, 19:53 |
You should model the physics as they are in the real world. If it starts from a steady state condition then yes, start with a steady state simulation. If it starts from a known condition (ie from rest, or some other known condition) then start straight into the transient simulation. Glenn Horrocks |
November 12, 2008, 06:08 |
Nonlinear k epsilon Shih Model | idrama | OpenFOAM | 10 | March 12, 2018 14:35 |
ERROR #004100018; Fatal overflow in linear solver | Attila | CFX | 1 | April 13, 2012 23:22 |
Linear System solver in Newton method | proto84 | Main CFD Forum | 3 | November 30, 2009 11:06 |
free C code for large sparse matrix linear solver | ztdep | Main CFD Forum | 7 | May 24, 2007 15:14 |
linear solver failure when using SST model | fanzhong Meng | CFX | 4 | March 21, 2006 21:16 |
