How to specify partition count for local parallel
Old   October 16, 2008, 06:24
Default How to specify partition count for local parallel
rohit
Dear Users,
I have to start a run in local parallel mode by command line I use the command "cfx5solve -def file.def -par-local" but it does not start and says: You must specify a partition count for PVM Local Parallel
please somebody can help me as how can i specify the partition count in the batch
Thanks for your replies, Rohit.
Old   October 16, 2008, 18:42
Default Re: How to specify partition count for local paral
Try "cfx5solve -def file.def -par-local -partition 2". This is all discussed in the documentation, have a look there for all the command line parameters and examples.
Old   October 17, 2008, 04:48
rohit
Thanks Glenn
Parallel Run on dynamically mounted partition braennstroem OpenFOAM Running, Solving & CFD 14 October 5, 2010 15:43
parallel issue: global face zone/patch ... matteoL OpenFOAM Running, Solving & CFD 2 June 16, 2010 07:22
Basic rules for mesh partition for parallel runs hsieh OpenFOAM Running, Solving & CFD 1 December 24, 2006 12:07
basic rules for partition domain for parallel run phsieh2005 Main CFD Forum 19 September 18, 2006 10:34
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 Amitava Majumdar Main CFD Forum 0 January 5, 1999 13:00
