October 15, 2008, 05:56 |
[CFX-Mesh] body selection
Good morning, I am a new CFD user, I do my diploma work about a aerodynamic simulation in a High Ingeneer School in Switzerland.
How I can select the body (for example the wing) in CFX-Mesh to refine a face mesh or add inflations ? If I draw the half, I can do that without problem, but when I draw the full model, I can't select it because it's in the containing box. Thank you, I wait about your responses. |
October 17, 2008, 12:15 |
Re: [CFX-Mesh] body selection
Are you trying to edit in the Workbench mesher or in CFX-Mesh? If I understand correctly, CFX mesh used to be stand alone in WB10 but in WB11 it became a "method." You can specify CFX mesh method but still edit in CFX-Mesh. Right click on CFX-Method and select edit in CFX-mesh to bring up the CFX mesh interface. I think it'll be easier to work with the model that way.
John |
How to make appear edge/line body (created in design modeler) in the meshing tool | Rockda | ANSYS Meshing & Geometry | 6 | June 9, 2016 00:10 |
6DOF with floating body bounce back. | paka | FLUENT | 4 | June 6, 2013 12:32 |
Imported ICEM mesh has additional body in the mesh | Procyon | CFX | 1 | January 27, 2011 17:21 |
Body in windtunnel - high preassure behind the body? | Andyjoe | OpenFOAM | 4 | February 16, 2010 11:57 |
Body force at the cell face | Souviktor | Fluent UDF and Scheme Programming | 0 | March 31, 2009 09:54 |
