ICEM working directory setting
Old   October 6, 2008, 09:01
Default ICEM working directory setting
Bogesz
Can anyone tell me where could I re-set the default Working directory? I guess it should be stored in some config file or not... It's a bit annoying to click File/Change Working Dir/... 37million time every time I start ICEM
Thanks b
Old   October 8, 2008, 07:49
Default Re: ICEM working directory setting
rohit
Dear Bogesz,
right click on the Icem-cfd icon and select properties.. under properties you have select the shortcut tab, where you have field "start in" you can give the path of your default working directory.
Rohit
Old   October 8, 2008, 08:45
Bogesz
Thanks, good ol' windows "trick". Never would have thought of that...
[CGNS] CGNS converters available mbeaudoin OpenFOAM Meshing & Mesh Conversion 137 December 14, 2018 05:20
[ANSYS Meshing] Workbench 13: Structured Hexa Meshes rooftop ANSYS Meshing & Geometry 19 March 31, 2016 03:33
Gambit Default Working Directory Virgil Howardson FLUENT 5 December 19, 2009 07:13
Setting working environment variable Arthur FLUENT 0 December 10, 2008 05:33
Error: Unable to retrieve mon from working directo Atit Koonsrisuk CFX 6 February 20, 2004 06:07
