October 3, 2008, 05:43 |
Torque coefficient evaluation
Hi!
I was trying to analyse flow around a H-rotor, a type of vertical axis wind rotor. I made my rotor profile in gambit and set up the problem in fluent. I applied boundary conditions of velocity inlet, prerssure outlet, and farfield conditions. And I used K-epsilon turbulent model. I wanted to obtain the efficiency or power coefficient of the rotor. But the problem is that the torque coefficients, in the force monitor window section,were coming out to be negative. I am really in deep problem,as I am not able to make any further progress. I will be immensely glad and happy if someone of you suggests me solution to this. PLZ DONOT LEAVE IT FOR OTHERS, AS IT IS YOU WHO CAN HELP ME. THANKS! |
High torque coefficient Cm for Vertical Axis Wind Turbine (VAWT) | tony00 | FLUENT | 11 | July 23, 2018 07:13 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 09:56 |
torque coefficient | mokemex | FLUENT | 6 | March 10, 2010 10:53 |
Automotive test case | vinz | OpenFOAM Running, Solving & CFD | 98 | October 27, 2008 09:43 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 13:02 |
