Residuals converged but high
Old   September 30, 2008, 15:17
Default Residuals converged but high
Gilles
Hello CFD users ! I'm running a simulation over a 3D-Wing at 50m/s in a free stream. I use the SST-transition model. My solution converges but the RMS residuals are too high (about 1e-4), furthermore, I checked the lift and drag on the wing and it converges as well. Do I have the right solution ?
Thanks for your help
Gilles
Old   September 30, 2008, 15:19
Default Re: Residuals converged but high
CycLone
If the residuals are high it is not converged. Converged means the residuals are sufficiently low, not that they have stopped going down.
Check the solution for regions of instability. Increasing your timestep may help (try a factor of 10). Also, check the mesh for regions of low quality and fix them if necessary.
-CycLone
Old   September 30, 2008, 20:05
Try this page:
http://www.cfd-online.com/Wiki/Ansys...gence_criteria
High residuals ecram Siemens 4 April 20, 2020 12:14
Accuracy and convergence pawan1989 FLUENT 5 April 15, 2010 18:17
help high initial residuals Aly FLUENT 0 October 11, 2007 10:04
Help HIGH RESIDUALS Aly Fidelity CFD 0 October 11, 2007 09:57
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
