Areodynamic torque of butterfly valve
Old   September 30, 2008, 13:52
Default Areodynamic torque of butterfly valve
J.Szary
I'd like to calculate areodynamic torque of my butterfly valve. I've got only 3 datas: dimension of valve, pressure (1/3 atm) and i know that the air is releasing to the atmosphere. Can anyone help me and describe step by step what should I do? (starting with CFX-Pre)
Regards!
Old   September 30, 2008, 20:07
Default Re: Areodynamic torque of butterfly valve
Step 1 - Do the tutorials in CFX. There is even a flow in a butterfly tutorial problem so you might find that one particularly useful. Step 2 - Do the analysis based on what you learned in the tutorials. Step 3 - When you have more specific questions/comments about the simulation then raise a topic on the forum.
Old   October 1, 2008, 10:53
J.Szary
I've done a static simulation, but I'd like to simulate rotating disc. How can I initiate it? There is no option for cylindrical coords. I've red your post about making mesh diaplacement transformation, but I'dont know how exacly do it.
Old   October 2, 2008, 19:14
You want to move the butterfly in a transient simulation? You are the third person I have recommended to try the mesh deformation tutorial from the CFX-Tutorial Manual this morning.
Old   October 9, 2008, 17:50
J.Szary
How can I calculate the areodynamic torque?
Old   October 9, 2008, 19:52
Using the CEL functions torque_x, torque_y and torque_z.
Old   October 10, 2008, 13:05
J.Szary
Thanks a lot for your patience. I'd like to simulate a rotating valve (normally and rapidly rotated) and investigate a torque for this condisions . I tried mesh deformation, but the negative elemets has appeared. Maybe there is a better solutions for this problem?
Regards!
Old   October 12, 2008, 18:54
Put the valve is a rotating frame of reference and connect to the rest of the domain with a GGI.
Old   October 12, 2008, 20:01
J.Szary
There is a problem. I can't put solid valve in rotating frame (there is only stationary option). And how can I apply BS on my symmetry when I've already interface condision on it.
Regards!
Old   October 13, 2008, 18:51
Are you trying to do a CHT simulation with moving mesh or RFR? Why do you need the do CHT (conjugate heat transfer)? I am not sure if this combination is supported - better talk to the support office.
[ICEM] Blocking topology for pipe flow with a butterfly valve siw ANSYS Meshing & Geometry 13 November 27, 2012 13:07
Moving mesh with butterfly valve uorinopuot CFX 16 February 25, 2011 06:40
butterfly valve euzinho FLUENT 0 May 28, 2010 09:58
Torque for butterfly valve J.Szary FLUENT 1 September 5, 2008 18:28
butterfly valve C. K. Main CFD Forum 1 April 3, 2006 00:30
