Particle Tracking - Can't define water particles
Old   September 29, 2008, 09:05
Default Particle Tracking - Can't define water particles
CFDLife
Hi-
Using ANSYS-CFX, I am trying to simulate Spray using Particle Tracking. The problem involves air flow in a pipe, water is injected through an injector when the air is half-way through the pipe.
In the fluids list, i select both water and air. Then when i check the box - particle tracking, i cannot pick water from the particle list.
Am i doing something wrong here?
Please help asap.
CFDLife
Old   October 2, 2008, 07:28
Default Re: Particle Tracking - Can't define water particl
rohit
Dear CFDLife,
when you are using the particle tracking, you should not select the water in the fluid list..then you can see water in your partical tracking list.
rohit
Old   October 3, 2008, 07:12
sanjay pawar
Dear rahul if we select water in fluid list then also we have water in particle tracking list. so how to go further?
Number density tracking rather than particle tracking Rebecca Main CFD Forum 2 April 23, 2009 13:52
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
how to define particle mass fraction in the subrou Neser25 CFX 1 October 6, 2005 10:20
Particle Tracking Pravir Kumar Rai FLUENT 2 January 30, 2003 20:16
uptodate water distribution network fredius,magige,tanzanian,(e.a) Main CFD Forum 0 January 27, 2002 08:10
