September 27, 2008, 09:05 |
[urgent] ICEM: from 2D to 3D using extrude
I followed the ICEM tutorial: 2D pipe junction and define several blocks to mesh a 2D geometry. No surface was created. After converting pre-mesh to unstructured mesh, I used extrude to get one-element thickness in z direction. Then in the output Tab, I choose "ANSYS CFX" solver and write input file. However, when i tried to import the mesh (.cfx5) in CFX-Pre, always an error, saying that no mesh exists in the requested file. I has been stucked for several days. Would anyone please help me? Thanks a lot.
September 27, 2008, 17:30 |
Re: [urgent] ICEM: from 2D to 3D using extrude
Hi, my first suggestion: Did you define the ICEMCFD as a file format in CFX-Pre/Mesh_Import dialog ?
second: Has you checked the mesh by ICEMCFD mesh checking?Is it without problems? Zbynek |
October 2, 2008, 07:17 |
did the mesh is error free when checked in icem with check mesh? and second point when you export in icem is it doing the export without any errors?
March 11, 2010, 13:01 |
Joshua Counsil
Rep Power: 18 |
I is hasing the same problem. Any help?
ICEM CFD 5.0 - 2D to 3D Mesh Extrude | James Date | CFX | 7 | October 22, 2013 04:46 |
[Gmsh] Cannot get the right mesh from gmsh | JinBiao | OpenFOAM Meshing & Mesh Conversion | 2 | August 31, 2010 05:51 |
Extrude mesh in ICEM CFD | Susan | CFX | 2 | November 5, 2007 18:10 |
EXTRUDE option in ICEM CFD Geometry | Mohammad Faridul Alam | CFX | 4 | October 25, 2007 18:47 |
How to extrude 2D Mesh in ICEM CFD? | VSB | CFX | 7 | December 27, 2006 12:58 |
