Thermal Radiation of a bulb
Old   September 25, 2008, 10:48
Default Thermal Radiation of a bulb
Andy
Dear CFX-Community,
is there anyone, who knows where to get a tutorial about "Thermal Model of Head Lamps using DO Radiation Model"? I read about it in some previous postings, but could not answer them anymore. If there is no such a tutorial, perhaps you can give me some hint, how to simulate the thermal radiation of a bulb.
Thanks a lot,
Best regards, Andy
Old   September 27, 2008, 09:59
Default Re: Thermal Radiation of a bulb
Johnson
Andy,
I don't think there is a tutorial on lamp modelling.
However, the best way to model a lamp is by using a fixed, high temperature boundary to model the filament, with an emissivity = 1. The relative proportions of Convective and Radiative heat flux are then part of the solution.
If you know the filament radiative flux but not the temperature, you can adjust the temperature until you get the correct value.
Johnson
Old   September 29, 2008, 04:30
Andy
Thank you Johnson,
My whole simulation is about the tmeperatures around the bulb. I want to know, where which temperature appears.
If there is no other possibility fpr modelling the heat flux of the bulb, I think i try it in this way.
The Halogen-Bulb is running with a wattage of 20W. My problem is, where do I set the boundary condition if I do not simulate the bulb exactly like Johnson explains?
Thx Andy
Modeling Thermal Radiation Kaushik Saha FLUENT 0 September 17, 2008 20:12
Radiation in power supply thermal simulation Jitender FloEFD, FloWorks & FloTHERM 3 September 5, 2008 04:09
Opaque - Thermal Radiation Subha CFX 3 March 11, 2008 18:37
About thermal radiation koukouken CFX 1 February 23, 2006 06:01
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 11:18
