natural convection square cavity
Old   September 22, 2008, 05:39
Default natural convection square cavity
tommy
Hi !
I'am doing some simulation about natural convection in a square cavity by using cfx 10.0. Just for curiosity, i did a few of calculation using a 3d box with 10 elements in the direction of the thickness and with simmetric boundary conditions on each side in the direction of the thickess. The solution present also a non zero velocity in the direction of this thickness in some grid point. Why ??
Old   September 22, 2008, 19:39
Default Re: natural convection square cavity
Are you saying there is velocity across a symmetry plane? Or are you saying the flow is not planar? Many convection driven flows break up into non-planar flows so this is to be expected.
Old   September 23, 2008, 04:42
tommy
Hi !
The predictions show a not planar flow !
Old   September 23, 2008, 20:31
Well, as I say this is normal for convection driven flows. They only remain planar at very low Rayliegh numbers.
Radiative heat transfer with natural convection inside a square cavity msarkar OpenFOAM 1 January 11, 2010 23:21
natural convection in square cavity Dhileep Main CFD Forum 0 January 11, 2009 11:29
natural convection in a square enclosure with a partial dividing wall sandeepmishra FLUENT 3 May 6, 2000 05:25
natural convection in a square enclosure with a partial dividing wall sandeep Main CFD Forum 0 April 30, 2000 01:38
