viscous layer moves
Old   September 16, 2008, 05:26
Default viscous layer moves
Igor-a
In my simulation I have found Mach number 0.2 at the stationary wall. Turbulence model is K-epsilon, y+=10 on the wall. What i have made wrong?
Old   September 16, 2008, 07:34
Default Re: viscous layer moves
Igor-a
I was meaning: speed of air flow at the stationary wall is bigger than zero... it is nonsense, but i dont understand how to get correct result
Old   September 16, 2008, 11:08
John S.
Are you calculating a convervative or hybrid value?
Old   September 16, 2008, 14:41
CycLone
Hi Igor,
The "conservative" wall node values actually represent the half volume next to the wall. The "hybrid" values will give you the boundary value (zero for a no-slip wall wall).
I suggest reviewing the documentation on hybrid and conservative values in the CFX on-line documentation. You can also search this forum for many discussions on the topic.
-CycLone
Old   September 17, 2008, 03:26
Igor-a
Oh, thank you very much for help )))
Old   September 17, 2008, 04:36
Igor-a
However in Hybrid values contour i see Mach number=0.13 on the no-slip wall...
Old   September 17, 2008, 15:18
CycLone
Verify the colour details of the surface you are plotting. If the "Conservative" radio button is selected, the plotted values will be zero.
-CycLone
Old   September 19, 2008, 02:24
Igor-a
Sorry , i was wrong, my problem was influence of friction on matched wall
Thankk for help!
[snappyHexMesh] SnappyHexMesh - no layer added bejbro OpenFOAM Meshing & Mesh Conversion 5 February 1, 2020 21:05
[snappyHexMesh] Boundary layer in a pipe Clementhuon OpenFOAM Meshing & Mesh Conversion 6 March 12, 2012 13:41
[snappyHexMesh] Boundary layer generation problems ivan_cozza OpenFOAM Meshing & Mesh Conversion 0 October 6, 2010 14:47
errors Fahad Main CFD Forum 0 March 23, 2004 14:20
boundary layer upon viscous wall Xavier TRICOT Main CFD Forum 2 September 20, 2000 05:40
