How to set the name of a .res file?
Old   September 5, 2008, 06:06
Default How to set the name of a .res file?
Georg
Hi all,
You know when CFX solver runs .def file which has a name "project.def", solver names .res files like "project_001.res", "project_002.res", etc. What can I do to change the name of .res file? I want all runs of solver generate .res file with the same name (for example, "project.res", without a changing part of the name), and new runs overwrite .res file.
Thanks for your responses!
Old   September 6, 2008, 14:37
Default Re: How to set the name of a .res file?
Chebeba
Invoke CFX from the command line.
For example:
cfx5solve -def foo.def -ccl bar.ccl -name XXX
The result file will be XXX.res
[OpenFOAM.com] OpenFOAM 1.7.1 installation on LINUX UBUNTU 10.10 electrosin OpenFOAM Installation 40 May 31, 2016 06:11
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
[OpenFOAM] ParaView 33 canbt open OpenFoam file hariya03 ParaView 7 September 25, 2008 18:33
[OpenFOAM] Paraview command not found hardy ParaView 7 September 18, 2008 05:59
PHI file structure Eugene Phoenics 9 November 2, 2001 23:00
