September 5, 2008, 02:23 |
CFD for rotary components
Hello everybody,
I am completely new to CFD field, but I did some exercises on normal flows through stationary objects using tutorials in Ansys CFX-11. Now I have a trouble when i am implementing on real term objects. I am trying to analyse airflow for a centrifugal blower as a sucking effect through a heat exchanger. I couldn't find any supportive tutorial to simulate rotary components. Hence i used a multiphase tutorial and I picked concepts of frozen rotor, rotational periodicity etc and tried implementing but cannot succeed for rotational behaviour of air flow. Can any body Pls help in finding a supportive tutorial so that I can have a joy. Thanks in advance. |
September 8, 2008, 05:28 |
Re: CFD for rotary components
Hello Genius people,
pls respond back. |
September 8, 2008, 11:25 |
Hi Ajit, Use Transient Rotor Stator model instead of Frozen Rotor.
September 10, 2008, 04:46 |
Thanks farid. I will surely try this and get back 2 u asap.
September 10, 2008, 10:03 |
You are most welcome Ajit.
September 23, 2008, 01:29 |
hi ajit and Farid I think u should try single rotating domain becoz fluid is air.Then go for Two domain.
if u are trying Frozen-rotor or transient rotor model then u have to go for two domain. I think this problem can be handled in single domain. well, what is gap between blades and housing (outer vessel)? |
October 2, 2008, 01:07 |
Hello Sanjay,
Thanks for your suggestion. Kindly forgive my ignorance but Is there anyway you can post me a hyperlink for any tutorial for simulating rotary components,please. |
CFD Wiki - We Need More Help | Jonas Larsson | Main CFD Forum | 13 | September 13, 2005 18:36 |
CFD for fans & blower housings | David Carroll | Main CFD Forum | 8 | August 24, 2000 18:25 |
PC vs. Workstation | Tim Franke | Main CFD Forum | 5 | September 29, 1999 16:01 |
CFD and fluid power components | Paul Hancock | Main CFD Forum | 4 | June 14, 1999 07:15 |
Which is better to develop in-house CFD code or to buy a available CFD package. | Tareq Al-shaalan | Main CFD Forum | 10 | June 13, 1999 00:27 |
