Problem with cfx Solver Results
Old   August 26, 2008, 06:00
Default Problem with cfx Solver Results
Ordoumpozanis
Hi
I am running a case of double facade with buoyancy. I have adiabatic walls except one witch have a heat flux and a boundary of p=patm at inlet and m= const at outlet. I noticed that at outlet, the velocity that I get is different from the velocity witch I expect. I tried to run the same case with boundary condition of normal velocity = const at outlet and the mass flow that I get is different from the one I except. In the problem I use a K-e model with constant density.
Can anyone think a reason for this situation ???
Tnanks
Old   August 26, 2008, 17:25
Default Re: Problem with cfx Solver Results
CycLone
What velocity did you expect?
Old   August 26, 2008, 19:15
brunoc
So, correct massflow = wrong velocity correct velocity = wrong massflow
Is the density of your material correct? Can you assume it to be constant?
Old   August 27, 2008, 05:07
Ordoumpozanis
Hi, thnk for the reply. I managed to get the right results by adding the normal velocity only to the calculations on the boundary, witch is logical. but if I check each cell on the boundary, the equation of Acell = mass flow (m3/s)/ velocity (m/s) is not equal to the area of the cell on the boundary. The values for the calculations are output from post process
thnks again
Old   August 27, 2008, 12:54
CycLone
Hi Ordoumpozanis,
This is actually expected. The solver calculates mass flow rates at integration points, where the velocity is not equal to the nodal velocity. If you calculate the mass flow rate as rho*A*V, you'll actually get the wrong results. Post avoids this error by using the integration point mass flows, which are written to the results file from the solver.
The actual calculation of mass flow rate at the integration point is rather involved and must include the spatial variation of both velocity and pressure. You can review how this is discretized in the solver theory guide.
-CycLone
The ANSYS CFX solver exited with return code 1 kola77 CFX 24 April 11, 2022 08:32
mesh.update problem in a new FSI solver ICL OpenFOAM 0 October 8, 2011 15:16
CFX pressure in Simulations problem nasdak CFX 1 April 14, 2010 14:22
CFX Solver problem seojaho CFX 2 October 14, 2009 15:33
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 05:07
