CHT in porous domain?
Old   August 23, 2008, 21:48
Default CHT in porous domain?
frank
Hi all,
I am working with porous material and heat conduction in it. But I find CFX can not do such a job. When come to energy equation in porous domain only gas part is involved in. So I want to add solid heat conduction part in its heat source term.
But another problem rises up. How can I realize the second derivative of T in fortran subroutines. Any comment will be appreciated.
frank
Old   August 26, 2008, 17:30
Default Re: CHT in porous domain?
CycLone
Hi Frank,
Instead of doing this through user fortran, create an additional variable for your porous CHT temperature and solve it within the porous domain using the "Diffusion Equation" option. You can then add a volumetric source/sink pair between the fluid temperature and your AV to represent the volumetric heat transfer within the porous region.
-CycLone
Interface between fluid domain and porous domain windhair CFX 6 May 10, 2018 15:26
Radiation at interface between fluid and porous domain Hitch8 CFX 19 April 20, 2015 07:24
Material identification between a flow domain and a porous domain Ervideiro CFX 1 June 1, 2010 10:50
heat transfer in porous domain Tiago CFX 3 October 19, 2008 02:20
CHT Problem - Domain Imbalance Parthipan CFX 5 September 11, 2007 11:13
