Streamlines end in domain
Old   August 22, 2008, 12:51
Default Streamlines end in domain
Boris
Hello CFX Users,
I am simulating the flow in a Ranque-Hilsch Vortex tube. (Vortex Tube with one Inlet and a Hot and Cold exit) Finally the computation meets the default residual target of 10e-4 and ended normally. When I look at the streamlines starting at the Inlet, they end in the middle of the domain end do not follow to the outlet.
What could be the reason for that?
Thanks, Boris
Old   August 22, 2008, 19:23
Default Re: Streamlines end in domain
John S.
Make sure you've run enough interations that the flow actually has enough time to advect completely through the domain. I generally set my convergence criteria really low (1e-8) and monitor convergence so I can stop it when I feel it's ready.
Old   August 23, 2008, 04:09
Boris
Thanks a lot. It was much easier. I have Periodics in my Domain and the default Limit for Max Periods is 20. As I have hundred of turns in my vortex tube I just need to set the limit up ;-)
Old   August 23, 2008, 13:23
John S.
Ah I see. Also if you don't check the 'cross periodics' option, the streamlines will not cross the periodic boundary and stop.
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
CFX does not continue Shafiul CFX 10 February 17, 2011 08:57
CFX Parameters Settings Flaky CFX 21 October 28, 2010 19:16
Single Bubble Gerrit Senger CFX 4 March 12, 2007 17:29
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 13:02
